Re: SWG and gas heater
I agree with Dave. Keep your water balanced and keep a watch on your PH and total alkalinity especially and you should be fine with a copper heat exchanger. I would also recommend having a check valve installed. What that does is when the pump is shut off, no water can back up into the heater.
Inground 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWG
