Thread: Removing Metal stains
    .Joppa, Maryland
    Default Removing Metal stains
    I ordered stain remover on line assuming it was ascorbic acid, but it is oxyalic acid instead. (I also ordered ascorbic acid from the supplier in mbar's sticky). Can I use this and do I follow the same procedure as ascorbic acid?
    Thanks for your help
    Marty
    Default Re: Removing Metal stains
    yes
    However, ascorbic acid is toxic so be careful. FYI, you can also use citric acid.
    .Joppa, Maryland
    Thanks for the reply. I assume you mean oxalic acid, not ascorbic acid ?
    Marty
    Yeah, ascorbic acid is Vitamin-C
    Quote Originally Posted by MartyW View Post
    Marty
    yep, blonde momemt! (I refuse to say senior moment!)
    All three will remove some, but not all metal stains (some copper stains are just about impossible to remove).
    Ascorbic acid is the safests but the most expensive and it's price has gone up a lot lately. Oxalic acid is the least expenisce and is found in some commercial products such as United Chemical's Pool Stain Treat but is it very toxic and somewhat corrosive. Citric acid is just slightly more expensive than oxalic acid and is much more benign but still more irritating than ascorbic acid but not considered a poison.
    .Joppa, Maryland
    Should I be backwashing my DE filter during this process? Is there a way to eliminate the metals other than a complete water change?
    Thanks, Marty
    Only if your filter pressure rises too high.
    Basically, no, assuming there are no metals in the fill water. If you REALLY know what you are doing you can sometimes get them to 'stain out' on the filter media and then change out the media (DE in your case) but it's tricky at best for someone who really understands the chemistry involved and NOT something to try if you don't.
    Thanks, Marty
    Welcome!
  1. ? removing metal w/ floc, chlorine, & high pH to drop it out, and then vac to waste?
    By poolf7665 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2013, 01:30 PM
  2. Metal Stains ?
    By gfritz1 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-16-2012, 03:32 PM
  3. Removing stains from a gunite pool with ascorbic acid
    By lstinthot in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2012, 10:45 PM
  4. Removing rust stains
    By Timmeh in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-04-2012, 07:26 PM
  5. Metal Stains
    By Terry_Hope in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-14-2011, 09:11 PM
