I've moved to FL and now have my second pool (first one I maintained for 4 years, inground). Prev. owners said they'd had a recent problem with low chlorine and replaced the flow sensor on the SWG. When we moved in, the SWG was on 30% and pump was running for 8 hours.
My first tests with my oft-refilled PS-234S
yielded:
pH 7.2, maybe less
IF it is 7.2 leave it. It WILL rise with a SWG!
FC 23.0
Has the pool been covered? If it has uncover it for several hours every day (ideally while the pump is running for the full pump run time) . I would leave the pump at 8 hours and turn the output down. Also, once you start using the pool and have a bit more of a chlorine demand this will change and you might need to turn the output up.
CC 0
TA 90 (test turned blue initially, then yellow at 90)
High FC levels will beach out one of the indicatiors used in this test but the test is still valid with the blue to yellow color change, just harder to see. You CAN add a few extra drops of the chlorine neutralizer (first reagent) to help overcome this when you know you have very high chlorine. I would actually think about lowering this to around 70 once your pH comes up as you will have better pH stability and less acid demand with a lower TA
CH 320
CYA 90-100
Leave it alone. It's fine for a salt pool. Level is slightly high for an Aquarite but if you keep your FC at 4-5 ppm you will have no problems at all. It will drop on it's own during rainy season, which is coming up very soon here in FL!
Salt 3000
A bit low but livable. I like to keep it closer to 3400 ppm to compensate for the rains we get here in FL. That way wyen the water level goes up the salt is still ok.
I turned off the SWG!!! Slowly, but surely the chlorine has been dropping. Now, 9 days after my initial tests and no swimming, I tested:
pH 7.7
FC 10.0
CC .5 (maybe less)
I'm thinking I could do a partial drain to drop the CYA into the proper range for the SWG but is it really necessary right now?
NO!
With the higher CYA, is 10 FC swimmable?
In the state of Florida 10 ppm is considered swimmable in a commercial pool with CYA of 30-50 ppm (I've taken care of comemrcial pools here in FL. Over 10 ppm then a pool is closed. You are fine--go swimming!
I'd like to drop the FC just a bit more (maybe wait another day) and then turn on the SWG at a low level and monitor the FC level and add some muriatic acid. Don't add acid yet.
Wait for the pH to climb to 7.8 and then don't lower it below 7.5. This will maximize time between acid additions and prevent problems. The lower the pH the faster it will rise (don't ask me to explain, you will be sorry!) Never let the pH get above 7.8 or you are asking for problems.
Any other recommendations, thoughts??
Add borates to 50 ppm. It will help a lot with pH stability.
My signature reflects this "new" pool.
