First? Forget about TDS. You have enough issues that ONLY when they are FULLY resolved should you even THINK about TDS.
Second: Let's assume the tests he ran are correct.
Adding Borax is the place to start. If your TA is low, you can add Washing Soda instead as it will raise TA.
Remember: your TA will be lower with pH at 6.8 than at pH of 7.6--your REAL TA may be the same as well.
But it's no big deal--you can add Baking Soda with the Borax to raise TA as well. BTW, at 6.8 pH you may well need as many as four boxes of Borax and/or Washing Soda.
Third: You FC level is 'WAY too low, and you have a CC level showing up. So shock it up and keep it shocked up.
Fourth: Avoid the pucks for now--they lower pH and you are dangerously low.
Fifth: You can, if you want, add stabilizer directly to get it where it needs to be. You should be able the run the CYA/Stabilizer test yourself because it doesn't require color perception--it's how cloudy the sample is.
Sixth: I don't know how severe you color blindness is--do you have reduced color perception, total inability to distinguish red from green, or complete monochrome vision?
For example, when using the FAS-DPD Chlorine test, can you see the water is pinkish red to start and can differentiate when it goes clear? If so, you can run that test.
If you can distinguish between red and green you can run the T/A test and the calcium drop tests as well.
I doubt you can run the OTO test for total chlorine, or the regular DPD test, or the pH test as they all require determining incremental changes in color--but the other tests may be possible for you to run. Still, if you can run the drop tests that the PoolForum kit, or the TroubleFree Kit has, then your only problem would be pH.
It just depends on how much perception you actually have.
