Results 1 to 10 of 15
Thread: Am I on the right track? New home w/pool
    North Florida
    Default Re: Am I on the right track? New home w/pool
    Thanks Carl & Evan. Just the info I needed! My previous pool and I had a nice "understanding" and we got along just fine with no problems...also an inground gunite, although with a different finish, and the same brand SWG.
    But this pool is in a totally different environment, so I'm not as confident in my approach, especially when the CYA is approaching 100 whereas my last pool ran nicely at about 60 - with SWG. From my limited experience, I think there's a sweet spot with every pool where it likes to settle, as far as readings are concerned. I knew my last pool...now I just have to get acquainted with this one.
    And, Evan, you mean this isn't the rainy season yet???!!!
    Sandy
    Quote Originally Posted by dawndenise View Post
    Wait unti Octoboer! Good new is once Hurricane season is past just about all of Florida is considered high dessert!
    Where in FL did you end up? The rains are worse in land than on the coast, IMHO.
    North Florida
    Fort Walton Beach area...sandwiched between Pensacola and Panama City. While we're not right on the coast, we're less than 20 miles inland. Wish I could say I lived in Destin, but no such luck...great beaches though!
    Update...SWCG is back on and chlorine is holding at about 8-9. I'll try to let it drop a bit further toward your recommendation of 5, but I found out that the prior owners had a nasty attack of black algae prior to moving out. Seems that a pool company was called in and had to do a whole lot of scrubbing (with dichlor???) to get rid of it. So far, the pool is nice and clear and I plan to keep it that way!
    Sandy
    If and when your pool is fully clear and clean, you should start adding Polyquat 60% as a preventative. You could add about 1/2 quart to start, then add 2oz every week and that should inhibit the black algae getting started again. Polyquat is easily recognizable by the contents: 60% poly...(something unpronounceable).... as the active ingredient. If you see something else and you DON'T see this, it ain't Polyquat 60%. Sometimes it's labled as algaecide, sometimes as Mustard Algaecide, sometimes as black algaecide. I don't care what they call it as long as it's got the 60% poly......
    Then you may be able to lower the FC safely. Beware, though: A heavy dose of Polyquat--like a half quart to a quart--will cause your FC to drop like a stone over the next 24-48 hours. Don't worry--with the SWG or shocking it will come back up. Just don't back wash for a couple of days.
    And the Poly acts as floc treatment, too.
    Good luck!
    You might also want to consider adding borates to 50 ppm instead of the polyquat 60. Not only does it have algaestatic properties, it will help stabilzie the pH also.
    You can even do both!
    With the borates, you'll need the special test strips. You'll also need acid to bring the pH back down as Borax is our recommend chem for raising pH.
    I haven't tried the borates 50ppm setting, but it makes a lot of sense.
    North Florida
    Thanks guys! I won't be able to add borates as I have 2 dogs that LOVE to drink pool water. After a walk, they're both really hot and they like nothing better than to jump into this pool's tanning/play area, swish their faces in and around the water and drink up some water. They did the same thing with our last pool, as well.
    I was part of a thread a couple years back when borates were first coming up as a topic and I think it was you, Evan, who mentioned you also had pets but had taught them not to drink from the pool.
    I could train them to not drink the pool water but I've just chosen not to...at least at this point.
    And, I am aware that high chlorine levels are also a risk to them, so had to manage their activities when the pool was first at FC=23. Would you still use PolyQuat in a pool where pets drank a good bit of water on a daily basis?
    Sandy
