Results 1 to 10 of 15
Thread: Am I on the right track? New home w/pool
    North Florida
    Default Re: Am I on the right track? New home w/pool
    Thanks guys! I won't be able to add borates as I have 2 dogs that LOVE to drink pool water. After a walk, they're both really hot and they like nothing better than to jump into this pool's tanning/play area, swish their faces in and around the water and drink up some water. They did the same thing with our last pool, as well.
    I was part of a thread a couple years back when borates were first coming up as a topic and I think it was you, Evan, who mentioned you also had pets but had taught them not to drink from the pool.
    I could train them to not drink the pool water but I've just chosen not to...at least at this point.
    And, I am aware that high chlorine levels are also a risk to them, so had to manage their activities when the pool was first at FC=23. Would you still use PolyQuat in a pool where pets drank a good bit of water on a daily basis?
    Sandy
    Quote Originally Posted by dawndenise View Post
    No. Not until I had a way to prevent them from drinking the pool water.
    Saint Cloud, FL
    Sandy,
    I did not see it mentioned in the previous threads, but you may need to keep adding muriatic acid to keep the pH down with a plaster pool, especially if it is fairly new.
    The calcium from the walls will keep leaching out until the conditions have stabilized.
    Pat
    North Florida
    Thanks for that reminder Pat. Although the home and pool are new to us, the pool was actually built in 2004-2006 time frame, I think. Sorry if my use of the word, "new" threw you...
    Sandy
