I'm assuming your CA reading is CYA? Shock the pool up to about 15 and try and keep it there for a couple of days and hopefully that will kill the algae. It may be that you aren't getting enough circulation in the corners and thus the algae gets started there. That is the problem that Al (Poconos) has had a couple of times. He rigged up a way to hook his vacuum hose up to the return in "blow mode" which causes the hose to snake around the pool. This seems to have helped him. Good luck.
