Filter Problem?
I have an above ground pool with a sand filter, I had some alge on the bottom of the pool so I hook the manual vacume and start cleaning the alge the vac was sucking it off the bottom but I noticed that the alge was coming right back into the pool from the jet. the bottom is clean but the water has a green tint was clear before.
Do I need to replace the sand? or is there somthing else wrong?
- You may not post replies
- You may not edit your posts
Forum Rules
