Thread: Filter Problem?
    Jul 2006
    Altamont,NY
    Default Filter Problem?
    I have an above ground pool with a sand filter, I had some alge on the bottom of the pool so I hook the manual vacume and start cleaning the alge the vac was sucking it off the bottom but I noticed that the alge was coming right back into the pool from the jet. the bottom is clean but the water has a green tint was clear before.
    Do I need to replace the sand? or is there somthing else wrong?
    Default Re: Filter Problem?
    Have you backwashed your filter lately? You shouldn't need to replace your sand. I'm on my 9th summer with the same sand with no problems. Some people have had theirs for even longer with no problems. You might try adding a little DE to your filter to help filter out the smaller stuff. There is a "sticky" at the top of this forum with more info about that. Sometimes when you have a lot of algae, it is a good idea to vac to waste instead of to the filter. You might want to post a complete set of current testing numbers.
    NJ
    I agree with watermom. Always vacuum loose algae to waste.
    Also, you can add a clarifier. It will make the fine particles clump together. WalMart has HTH for around $11 per gallon (vs. $20+ at the pool store). Then when you vacuum, the clumps will get caught in the filter and flushed away when you backwash.
  1. Filter problem?
    By marybee123 in forum Pool Equipment & Operations
    Last Post: 06-09-2011, 01:44 PM
  2. Problem Filter
    By Lenardo in forum Pool Equipment & Operations
    Last Post: 05-30-2010, 01:25 PM
  3. Problem with DE filter-
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 05-18-2009, 08:07 PM
  4. Do I have a filter problem?
    By justawildchild in forum Pool Equipment & Operations
    Last Post: 07-19-2006, 02:44 PM
  5. Filter problem?
    By Pamsel in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2006, 11:30 AM
