I agree with watermom. Always vacuum loose algae to waste.
Also, you can add a clarifier. It will make the fine particles clump together. WalMart has HTH for around $11 per gallon (vs. $20+ at the pool store). Then when you vacuum, the clumps will get caught in the filter and flushed away when you backwash.
