Re: PH Questions
It really depends....if pH is rising from aeration, then the more you aerate, the faster it rises, and the faster you can add acid to bring down pH and TA together.
But if the pH is rising from something else and the TA is going up with it, it will take far longer. The thing to do is check TA each time you bring the pH down to 7.2 and you'll see how long it takes.
