Thread: How to get antifreeze into lines
    Lutherville MD
    Default How to get antifreeze into lines
    I've searched through the various threads, but still have a question: we've blown out all our lines, and had no problem getting antifreeze into the waterfall line (it runs downhill!) How would you suggest getting antifreeze into the return lines, and into the skimmer line? Specifically, does it get poured into the returns from the pool end, or from the pump end? And does the skimmer line get filled from the skimmer or from the pump? Thanks for the help!
    Honesdale PA
    Default Re: How to get antifreeze into lines
    Basically you have to pour from the highest point. For the skimmer that is normally the pump basket. For the returns it would probably be from a pipe at the filter. Personally I just blow the water out of the lines and plug the returns and skimmer real well so water won't leak back over the winter. Filling my return pipes would take a lot of anti-freeze. I'll blow the lines with a shop-vac and put the caps on while under the slight shop-vac pressure. I then hook a special fixture I made to the appropriate pipe where the shop-vac was connected and pressurize the returns to about 15 psi or so to make sure nothing leaks. The skimmer line only goes to around 6-8 psi for the leak test as the pump basket is pressurized too and the lid could blow off. That run for me is short so I do fill that with AF.
    Hope this helps.
  1. Is antifreeze ok for pools?
    By burnszey in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-17-2011, 09:27 AM
  2. pool antifreeze
    By pc boy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-13-2011, 11:23 AM
  3. Antifreeze, Yes or No
    By joecus in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-16-2010, 12:18 AM
  4. Antifreeze in skimmer lines - and compressor choice
    By Tomcat in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-05-2009, 10:32 PM
  5. How much Antifreeze?
    By brian11 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-04-2006, 08:49 PM
