Re: pump trouble
I'll have my husband try that tomorrow-hopefully. It's starting to rain again and they're say it should last a couple of days-up to 2". He'll be thrilled to work out in the rain. Maybe it wouldn't be that safe? We'll see and I'll let you know what happens. Denise
Re: pump trouble
Another check is to cut power off and disconnect pump/motor from pump housing (volute). Try to turn the impellor/pump/motor by hand. If it's difficult or won't turn, the pump bearing/s (usually bearing nearest pump impellor) has siezed due to a leaking pump shaft seal.
See my post in "Pool Cleaning" forum for more details on pump repair.
good luck
