Results 1 to 10 of 16
Thread: Air Compressor Attachment/Adaptor & Questions
    Smile Re: Air Compressor Attachment/Adaptor & Questions
    The rubber plugs with the 'tire stem' shouldn't be hard to find. However, who needs them?
    Down in Va. when we'd pressure test lines, we used an air compressor, you could rig up something like we did. Using a properly sized male adapter, ~ 1' of schedule 40 PVC pipe and a glue on cap, you can drill through the cap and use a tap to install a 'tank valve' (tire stem with threads on the bottom).
    This would functionally replace the rubber plug with the tank valve through it and let you blow out the entire system from one skimmer (with the multiport on 'recirc'). It will cost more than the rubber plug (you need the M/A, pipe, cap and glue and primer as well as the tank valve and the tap) - but it's very simple to throw together and will last the life of your pool.
    If you still can't find the blow through plug and need any info on building what I just told you about, just give a holler and I'll help you build one
    Minnesota
    Default Re: Air Compressor Attachment/Adaptor & Questions
    See? My eyes started to glaze over on "using a properly sized male adaptor..."
    I wish I could just go buy one somewhere. So, yes, I WOULD like help in making one. I would PAY you!!! Or, alternatively, you can spoon-feed me directions. Starting with what the "properly sized male adaptor" is attaching to. The compressor? The PVC? AAahhh!
    I am vacillating on whether or not to do it myself. Temps are going to drop into the mid 20's early next week, so I might just call the pool co. cuz I'm feeling like a ninny.
    Honesdale PA
    Take a look at my post #17 in this thread:
    http://www.poolforum.com/pf2/showthread.php?t=261
    Minnesota
    Do you know if anyone has used the "ultra gizzmo?" It apparently has a blowthrough plug in the top of it. I can't find any good pictures of it, though, to see for sure if I am understanding it right.
    I don't know how to post a link here. but this is where I saw it:
    http://www.totalpoolwarehouse.com/It...emNo=411GIZ16U
    http://www.gizzmo.net/new/html/install.html
    Seems like -- if I am understanding it right -- it would do what your home made device would. I think it is designed to blow out thru the skimmers without lowering your water level. I, however, have always lowered water below skimmers and will continue to do so.
    Pool closers are set to come on 10/15 unless I can get it figured out before then. I'm still thinking about doing it.
    Minnesota
    Here is another picture I found of it:
    http://wetheadmedia.com/the-pool-gizzmo/
    Thumbs up Re: Air Compressor Attachment/Adaptor & Questions
    Sorry to have missed this part of the thread! The Ultra Gizzmo works very well for folks in your situation!
    Jennie sent me the following PM :
    jenmenke jenmenke is online now
    Member
    Default I'm gonna try to build your blow-out thing, but have a question
    I need some clarification on your response to my question about the adaptor for the air compressor -- asap because I want to start this today. Temps have been down to 20 and pool people aren't scheduled for another week. I'm worried:
    1) When you say "a properly sized male adaptor" you mean either 1" or 2" that screws into the bottom of the skimmer, depending on the size I have, right? (ours is 2")
    2) A tank (or schraeder) valve that comes out thru the top of the glued-on cap connects to the air compressor with a tire inflator compressor accessory, right?
    that's it for now. Hope you are around!
    What you describe is right on with what I was saying The threads would either be 1.5" or 2" - get the right male adapter, pipe and cap for your line. Oncew you've glued the pipe to the MA and the cap, drill a hole in the cap and use a tap to allow you to screw in the tank valve. (I think the tank valves are 3/8" - BUT DOUBLE CHECK THAT!!! Make sure you use terflon tape on any threaded connections!
    You'll also need some expansion protection in the skimmer! You can either cut up a foam 'noodle' and pack it into the skimmer body or ~1/2 fill an empty bleach bottle with sand or gravel and insert it upside down in the skimmer (the sand/ gravel keeps the bottle 'neutral buoyant' so that if ice forms, the bottle will collapse before the skimmer walls break)
    There are some other fine points in closing a pool, but the most important for right now are evacuating and plugging the lines (adding antifreeze to all the lines you can is also a VERY good idea) and draining the water out of the pump/ filter equipment. If you will tell us what you've accomplished, we'll tell you what else needs be done
    LUV & LUK!
    Ted
    Good luck with this, I'll check in in a couple of hours to see if you have any follow up questions
    Minnesota
    So glad you responded. OK, here is what I have accomplished so far. And I'm not AT ALL confident lines are blown clean
    I was going to make your adaptor and the more I looked at your directions, I couldn't see what the difference between the function of IT and the gizzmos I use every year. The gizzmo has removable plug on the end that a winterizing plug fits into perfectly. So I put a schraeder valve thru the winterizing plug and hooked my 135 psi air compressor up to that thru gizzmo that was screwed into the skimmer.
    The deep end return started blowing first. But it wasn't consistent air bubbles. What I mean is that it would blow big bubbles, stop for a few seconds and blow big bubbles again. I let it go for at least 15 minutes and it continued to do that with no change. So I figured that must be how it works. I worked my way around the 4 returns and then the polaris jet.
    Next I did the other skimmer. It blew water, but not up into the air like it does when the pool people do it. When they do it, water blows up like a geyser. Mine just "bubbled" and again seemed to bubble out, then suck in, bubble out, suck in... It did NOT instill confidence at all...
    Then I tried the main drain. I got lots of bubbles, then nothing. At no point after that first 15-20 seconds of bubbles did it appear that ANYTHING was coming out of the drain. No air, no water. No ripples in the dead calm pool water at all. Shouldn't there ALWAYS be bubbles or movement or SOMETHING?
    I couldn't figure out how to get air going thru the fountains. I wonder if that is a totally closed system. We never used them this year, but I think they still need to be blown. They have their own pump, but that pump hasn't worked for at least a year...
    Then I drained the filter (DE) by unscrewing the plug and the pressure gauge. I leave those off, right?
    Then I drained the heater (2 plugs) and turned the propane off.
    Then I drained the two pumps. (2 plugs each)
    There is 5" of snow forecasted for tonight. So I'm really hoping I will be OK for the next day or two. But I've got to figure out if there is still water in the lines.
    Biggest concern RIGHT NOW is the equipment, since water will no longer be circulating thru them: do the heater and filter and pumps just DRAIN or do they get BLOWN? All I did was drain and leave the plugs out.
    Should I ever hear ANY "gurgling" in the lines once the lines are "blown"? My guess would be NO. And I did hear some gurgling. So I"m concerned...
    I'm so sorry to be such a pain. Thanks for your time and help.
  1. Help..tear in vinyl liner at rope attachment ring....panic!!
    By heatherc in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-16-2012, 07:23 PM
  2. Please Help with Solar Cover attachment
    By JazzMan2010 in forum Pool Equipment & Operations
    Last Post: 05-26-2010, 09:07 AM
  3. Air Compressor Size
    By psteward in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-20-2006, 12:09 PM
