Thread: Hayward DE filter valve.
    Default Hayward DE filter valve.
    Hi everybody. I'm currently preparing to purchase a Hayward DE filter (DE3620) and a 6 position backwash valve. The problem I'm having is in locating the correct valve. About 1/2 the valves I see on the internet have the inlet/outlet ports on the left hand side while the other 1/2 have the ports on the right hand side. Hayward's site does not differentiate between these two valves, and, nowhere have I seen valves listed with right or left hand ports. How do I know which valve I'm getting? The instruction manual on Hayward's web site does show "optional" bottom and top port arrangements but nothing on side port arrangements. How do I order the correct valve? I'm needing inlet/outlet ports on the right side of the valve.
    Default Re: Hayward DE filter valve.
    Hi
    Order the valve you can get and, if it's 'backwards' we can help you plumb it in
    To be honest, I haven't seen them reoriented that way - if yours is, please tell me!!
    Thanks for the reply. I wish I could post pics. I need the plumbing ports on the right because that's the only way to situate the filter on the pad. I could use a left hand port valve but plumbing it would render an unwieldy maze of inefficient PVC piping. When I see pics of them actually installed, the ports are all on the right hand side. What's with the left hand ports?
  1. Hayward DE Filter Blew top of Air Release valve off??????
    By bell7272 in forum Pool Equipment & Operations
    Last Post: 06-04-2013, 08:34 AM
  2. Hayward SP-710 Valve Question
    By dlmcmurr in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2012, 06:22 PM
  3. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  4. Broken Hayward valve SP-711
    By Mckyjns in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 10:04 PM
  5. Hayward valve leak...
    By 98gtx in forum Pool Equipment & Operations
    Last Post: 06-25-2007, 02:23 PM
