Thread: Goldline AquaRite - no power light
    west1745 is offline Registered+ Thread Analyst west1745 0
    Dec 2005
    Default Goldline AquaRite - no power light
    Hi - please help!
    I have a Goldline AquaRite SWG - has been running trouble-free since January 2006. We went on a trip and came back to a green pool - zero cholorine!!
    The AquaRite has no lights on - meaning power LED light and generating lights are off - although it is showing the salt count to be 3200. I have kept it clean and serviced it at the proper intervals - so this is a surprise. It is hooked to a 2 speed pump and is supposed to be on and generating when the pump is on low speed- most of the day.
    I did check the fuse on the main panel - it is fine - I even changed it just in case - but that does not help.
    Any help or suggestions are greatly appreciated!!
    Last edited by west1745; 06-15-2008 at 07:40 PM. Reason: edited to add more details about the problem
    ____________________
    14K gallon inground pool
    plaster finish
    cartridge filter
    SWG - AquaRite
    Dolphin Diagnostic Robot
    Default Re: Goldline AquaRite - no power light
    What did you find out? I have the same problem
    I actually fixed mine yesterday. On the main circuit board there is a quarter size black disc in the top right hand corner. This is a current limiter, it was cracked and discolored. I ordered it from Digi-Key Corp., the part# is 570-1062-ND, and costs a whole 2.42 each. I ordered 2 and with shipping they were 7.34. I soldered it in, put everything back together and I am generating chlorine!
    Dec 2005
    Quote Originally Posted by Harley91 View Post
    Good job! Thanks for that info.
    plaster finish
    cartridge filter
    SWG - AquaRite
    Exact same probem, exact same solution...Up and running for under 5.00 dollars...Thanks to you guys..
