Thread: Need to replace failed Colorlogic light
    skamp is offline Registered+ Thread Analyst skamp 0
    Cypress, TX
    Default Re: Need to replace failed Colorlogic light
    Quote Originally Posted by waste View Post
    Steve, you got it!!
    Sometimes the hole where the conduit enters the niche is packed with putty, but, most of the time, it's exactly as you describe
    So are you saying the hole in the niche that the cable runs through is self sealing or something? It is at the bottom of my spa so I did not have a chance to look to see if there was putty or anything. Thanks!
    Cool Re: Need to replace failed Colorlogic light
    Steve, usually, they aren't sealed at all
    I was just saying that you may find some sort of sealer in there Once the sealant is removed, the light will be able to be pulled out and replaced in the way you originally posted
