I recently used a rubber strap wrench and was able to turn,...just barely. Parts are stainless so corrosion should not be an issue, but the impeller does seem to tighten w/ time.
There is a special tool that fits into the impeller to allow better grip/torque to be applied. Pool stores may have them. I took my pump to pool store and they removed impeller for me.
If seal has leaked for any length of time the bearing at front of electrical motor may be damaged. It can be replaced w/ some difficulty. See my post on general procedure.
good luck
