Thread: Pumping off pool cover water back into pool.
    Toms River New Jersey
    Default Re: Pumping off pool cover water back into pool.
    Richard,
    In the past just pumped water off cover onto the lawn. With water cost rising I will pump water back into the pool using your T Shirt method. I won't pump off the cover completely just the cleaner surface water. Thank You .........Walter
    Ohio, North Canton
    I've been pumping my cover water into my pool for the past 3 years.
    I usually take my leaf net and clean all the big stuff off of the cover before pumping, and I don't pump all the water off the cover back under to the pool. The last bit of water on the cover is pretty murky.
    When I do this, it does turn the pool water alittle funky looking, but usually within a day or two it is cleared up pretty good.
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
