Thread: Pool opening nightmare
    Birmingham, AL, USA.
    Default Pool opening nightmare
    Took at peek under the cover yesterday to discover the liner has completely ripped pool completely empty. I knew the liner was in bad shape but not this bad. I guess I just threw away $200 for the cold water dive to repair a small leak in November. Anyway I need suggestions on a new liner and I need to repair a crack in the pool deck by the stairs. I figure while the liner is out would be the time to fix.
    I have an idea of who to use to get the liner but who do I call about the pool deck crack?
    See photos attached
    Default Re: Pool opening nightmare
    Wow, is that rip in the same place that you had the leak fixed? How old is your liner? Judging by the coloring in your first pic, it doesn't look that old--any idea why it ripped like that?
    I think to fix the crack in the deck I would start with the people that put it down to begin with, if you had it done. If not, then any reputable concrete person should be able to fix it.
    No the rip was in a different location than the patch. I'm hoping it was just the cold and not a more serious problem. Not sure how old the liner was although it had several patches so it was pretty brittle.
  1. Every Pool Owner's Worst Nightmare
    By elsie in forum General Interest
    Last Post: 09-12-2008, 11:00 AM
  2. Spring opening, nightmare.......well, sort of
    By likesspace in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-27-2008, 11:52 AM
  3. HELP! Above ground pool nightmare!
    By mmstampa in forum Above-Ground Pool Construction & Repair
    Last Post: 07-29-2006, 12:56 AM
  4. AG pool company nightmare
    By kaydee in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2006, 02:21 AM
  5. Opening - Last year, a nightmare. This year, perfect...??
    By bcb1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-30-2006, 10:01 AM
