Results 1 to 3 of 3
Thread: Has Anyone Made A Homemade Inline Leaf Catcher??
    Jul 2006
    SE Georgia
    Default Has Anyone Made A Homemade Inline Leaf Catcher??
    Has anyone ever attempted building a large inline life catcher.
    I have a Zodiac Barracuda G4 cleaner. I also have the the matching inline leaf catcher. Both work great, but in the spring, when cleaning up to pool after winter neglect, the leaf catcher fills quite quickly.
    I was thinking about building a larger one, but wondered if anyone had already attempted this.
    I was thinking about a 5-gallon bucket (screw on lid) with some sort of mesh separator running vertically down the center. Inlet on one side, outlet on the other. Small drain valve near the bottom.
    Where's a good place to get the inlet and outlet connectors (bulkhead fittings)?
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    mas985's Avatar
    Pleasanton, CA
    Default Re: Has Anyone Made A Homemade Inline Leaf Catcher??
    By the time you put all the parts together, you probably could buy one.
    http://cgi.ebay.com/POOL-LEAF-TRAP-f...item2eaa9e14a4
    Mark
    Jul 2006
    SE Georgia
    You're probably right, mas, but I was hoping to come up with an industrial-sized leak catcher that I wouldn't have to empty as often during vacuuming and pool cleaning.
  1. next question-inline chemical feeder?
    By kimkats000 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 11:03 AM
  2. SWG vs. Inline Chlorinator + Ozonator
    By Chessie in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2010, 09:24 PM
  3. SWCG vs Manual/Inline Chlorinator
    By jmce1587 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2006, 09:48 AM
  4. Pool Kit comes w/ Inline chlorinator- can I use it w/ BBB?
    By hoffmans in forum Pool Equipment & Operations
    Last Post: 08-06-2006, 08:24 PM
  5. Inline Feeder
    By Coolflee22 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2006, 02:14 AM
