Thread: SWG and return jets.
    court475 Guest
    Default SWG and return jets.
    I am adding a SWG to my 14k gallon AGP. It is a Aqua Trol unit from Goldline that hooks up to the return jet. I have 2 return jets and understand that I need to install the cell before these 2 jets and after the filter. Just want to get some advice on what I would be losing if I went from 2 jets to one.
    mas985's Avatar
    Pleasanton, CA
    Default Re: SWG and return jets.
    Why would you need to go from 2 returns to one? Just nstall the SWG after the filter before the lines split. If you can't do that then just install the SWG on one of the two returns. You can still have two returns.
    Mark
    court475 Guest
    Just wanted to know the advantages/disadvantages. that's all. That's exactly what I did, installed between the 2 jets.
  1. air in return jets and my ordeal
    By sunofthebeach in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2013, 11:26 AM
  2. Air from return jets
    By cdsn99 in forum In-Ground Pool Construction and Repair
    Last Post: 04-25-2012, 06:33 PM
  3. Air bubbles in return jets
    By fog80 in forum Pool Equipment & Operations
    Last Post: 07-01-2010, 10:21 PM
  4. Spa return jets where to buy?
    By john509 in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2010, 12:04 PM
  5. Air Bubbles in the Return Jets. My Fault?
    By ccostan in forum Pool Equipment & Operations
    Last Post: 05-26-2007, 05:39 PM
