My Hayward Pump assembly has a slight leak ( damp area under pump) and is making a hissing sound. The water flow through the pool lines seems fine and the pressure gauge may be slightly high at 22 PSI (usually 18 PSI) Does that indicate a defective shaft seal or some other defective part?
