Results 1 to 8 of 8
Thread: Wall Fitting broke geez.
    Angry Wall Fitting broke geez.
    Hi everyone.
    Ok I got a new Polaris 280 (the old one was 5 years old) and thought my pool cleaning problems would be resolved. Hooked it up, connected it to the return line and the thing barley moved, wheels rotated about 11 rpm. Since the Polaris was new, I figured it must be a return line preasure problem, I was going to remove the restrictor disk so I try and unscrew the wall fitting to remove the disk and it cracks leaving half, part of it still connected in the wall. Now I got two problems that I hope someone on the board can help with. One being - how do I get the broken piece out of the wall fitting and 2 what might be the cause of the poor preasure on my booster pump, could it be the impeller?
    Thanks everyone
    -Frustrated
    Honesdale PA
    Default Re: Wall Fitting broke geez.
    The low pressure could very well be junk tangled in the impeller. Someone recently had that problem. As for the fitting, have to think on that but is it above or below the waterline? I'm not familiar with these hookups.
    Thanks Al,
    It's about 5" below the water line. I'm going to drain the water so I can get to it and attemp to remove the old wall fitting. Hopefully I can. Once thats done I'll have a try at replacing the impeller. Do they normally glue those wall fittings it sure is stick in there...
    -Lyle
    Honesdale PA
    I don't know about those fittings. As for the impeller, no need to replace it. Make sure it can't come on and reach in through the inlet hole at the bottom of the pump basket chamber and see if you feel anything tangled in it. If you do you can use a hooked wire or something like that to pull the stuff out. Can't emphasize it enough to make sure it cannot come on from a timer or someone throwing a switch accidentally.
    Trust me I shut the pumps down via the main power switch. I was not aware the booster pump had a basket chamber. Its got a Volute but I dont see a basket chamber.
    Smile Re: Wall Fitting broke geez.
    UPDATE: I was able to get the broke piece of the UWF out of the return by chipping away at it with a screw driver and hammer being careful not to damage the threads of the return line. I did have to lower the water line so I could get to it. I also installed a new impeller and seal on the boster pump and BAM it came back to life what a difference
    COOL
    I was debating whether to tell you to attack it with a screwdriver or not
    Honesdale PA
    Cool too. I didn't catch the thing about a booster pump. Glad all is well again.
  1. polaris 380 leaking from wall fitting
    By ellry99 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-18-2009, 04:02 PM
  2. Universal Wall Fitting Broken and Stuck
    By DanS in forum In-Ground Pool Construction and Repair
    Last Post: 05-31-2009, 07:07 PM
  3. How to replace wall fitting?
    By brian11 in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2006, 07:42 PM
  4. wall return fitting
    By bethsg in forum Pool Equipment & Operations
    Last Post: 05-20-2006, 02:24 PM
  5. Wall fitting question
    By Condo Steve in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2006, 06:33 PM
