Thread: Clorox Regular bleach is slippery
    Default Re: Clorox Regular bleach is slippery
    The generic bleach that I get from WalMart has a yellowish-green tint to it and is "slippery" feeling, so that wouldn't concern me as long as what you have isn't scented.
    There was a problem that a lot of people here had with the Clorox bleach last year--thnk it had something to do with the "new and improved" stain fighting formula that caused white deposits on the pool floor. Might want to search Clorox for posts within the last year regarding that. However, I wouldn't worry about the color and feel--that's normal.
    Edit: Here's a thread about the "new, improved" Clorox--the formula in question appears as a white liquid, so it sounds like you've got the right stuff. http://www.poolforum.com/pf2/showthr...=Clorox+Bleach
    Pretty much any bleach or chlorinating liquid is going to feel slippery. It's due to the high pH and also occurs from a solution of lye as well. This is normal and is because the high pH saponifies the oils in your skin (essentially making soap out of your skin oil). Once diluted in the pool water, it won't feel slippery at all, assuming you are properly maintaining your pool's pH.
    Thanks for your replies - that makes me feel better
