Results 1 to 10 of 17
Thread: Low calcium hardness in vinyl pool ok?
    Greenville, SC, US.
    Default Low calcium hardness in vinyl pool ok?
    Just a quick question y'all. Just tested the water (per Ben's pool testing kit) and my Calcium Hardness is 60ppm, which is low... BUT, my question... is it really necessary to have the Calcium Hardness up to levels in a vinyl pool ?? Is this really needed to keep the water correct or just important for concrete pools? Thanks in advance.
    We're really excited here in SC... pool water is up to 75 degrees... it's swimming time y'all !!
    RockG in SC
    Default Re: Low calcium hardness in vinyl pool ok?
    I wish my pool was 75 degrees. Don't worry about the calcium hardness level for your vinyl pool. Go swim.
    You only need to worry if the calcium level is too high--then your water can get cloudy (but it's still safe).
    Pool stores will give you an AMAZING song-and-dance about why you need calcium in your vinyl pool. It's nonsense.
    Greenville, SC, US.
    Thanks y'all... I thought I had read on here that it was ok. I do appreciate you both. Carly, btw, I officially started swimming today !! The kids jumped in so dad could NOT wimp out. Gotta tell you, it feels great !!!
    Thanks again to the both of you !!!
    May 2010
    If you have a heater with a copper heat exchange and your hardness is low it can destroy your heater. If there are any exposed metal parts in your pump or filter then your water when it is too soft (below 150ppm) your water can be corrosive as well. Most newer pump and filters won't have any exposed metal though and you should be find. If you have a vinyl liner and no heater 150ppm is a good point to stay at if you have a heater I usually recommend 250ppm just to be safe.
    Hi Shaggy;
    Watermom asked me to take a look at your post -- she's right, it reads like you've been drinking a lot of the pool industry koolade, whether you are in the biz or not.
    Several important points:
    1. Low pH will damage copper pool heaters; low hardness does not.
    2. Hardness -- at ANY level -- is only an issue in a 'plastic' pool (PVC pipes, vinyl liner, polymer pump) if it's HIGH. A hardness of 10 is fine in a plastic pool.
    In general, the whole saturation index thing the pool industry has wasted so much paper on, doesn't apply to most pools. It's significant in PLASTER (cement & marble dust) pools, but overblown or inapplicable almost everywhere else. The entire situation is a mess.
    If you are a pool owner, the answer is don't worry about it much unless it's too high, or unless you have a plaster pool.
    If you are in the pool biz, this is a discussion that belongs in the China Shop.
    Best wishes,
    PoolDoc
