Any chance there is too much crud in the skimmer basket? That would match the issue being solved after the pump turns off for a few minutes.
I'm thinking that you are clogging the skimmer basket and then, after the filter shuts off, some of the debris floats up, opening fresh channels in the basket, for a short time.
You may also have some 'stuff' collected in the pump basket.
Check your baskets and let us know if that IS the culprit![]()
