Thread: ML measuring container
    Mahwah, NJ, USA.
    Default ML measuring container
    Any suggestions where to get a new measuring vial for the DPD chlorine test? Mine is pretty stained. I'd also accept suggestions on cleaning it
    Default Re: ML measuring container
    I'll have to do some research on where to find a new vial because they all are a bit different, but if it helps, 5 mL=1 teaspoon of liquid.
    Might try an alcohol-soaked cotton ball or cloth on the inside of your existing vial and see if that helps.
    Lehigh Valley, PA
    Any tall and narrow cylinder would do. You could check at BedBathBeyond or other HHG store in the glasswares or stemware section for something suitable. Then you can use your existing test cylinder to measure 10 ml and 25 ml and mark the new container with an indelible pen, or even etch lines with a Dremel tool.
    AnnaK
    You can even get eyedroppers marked with 100ml. I would recommend the glass ones, though. It's a great way to do it: Add 100ml of your liquid chlorine to 10 liters of tap water (five 2-liter soda bottles) and the dilution rate will be in parts/per/million. Use your FAS-DPD chlorine test kit to measure the chlorine level and that's how strong your liquid chlorine is.
  1. Measuring Chlorine?
    By Shredhead in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-17-2013, 05:49 PM
  2. Proper Measuring Level BBB (Hot Tub)
    By mjones0089 in forum General Interest
    Last Post: 06-29-2012, 05:45 PM
  3. Will a sealed container of water hold chlorine forever?
    By sunofthebeach in forum General Interest
    Last Post: 07-25-2010, 05:10 PM
  4. Container to Clean DE Grids
    By donfranko in forum Pool Equipment & Operations
    Last Post: 04-25-2010, 04:51 PM
  5. Measuring Cyanuric Acid - can this help?
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-04-2008, 11:46 PM
