Results 11 to 16 of 16
Thread: Ozone smell
    Lehigh Valley, PA
    Default Re: Ozone smell
    You mean I shouldn't have bought that stuff and dumped it in????
    Just kidding.
    I said thank-you for the water test and I said I'd give the calcium a miss this time since my vinyl liner didn't require feeding.
    AnnaK
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by CarlD View Post
    Calcium is used to protect the calcium carbonate in pool walls in the cement, mortar, shotcrete, plaster, etc. It keeps it from leeching out. Therefore it's useless in vinyl pools.
    BUT there is some evidence it is useful for fiberglass pools!
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by AnnaK View Post
    And I realized the other day exactly what this smells like: a busy photocopy machine. It seems I notice the odor more on really humid days.
    Odd.
    Sounds more like your liner giving off the smell. Photocopy machinies fuse a plastic toner onto the paper. Is the liner new? They often give off an odor when they get warm (and are new).
    Quote Originally Posted by waterbear View Post
    I don't know the chemistry of FG pools too well, but I cannot imagine how calcium interacts with glass and the resin used to bind it. I'll let Ben and Chem_Geek work that out. People forget: Fiberglass is actual glass--super-thin threads of it.
    Lehigh Valley, PA
    The liner is in its 5th season this year.
    I think I figured out what the smell was: the remains of trichlor pucks in the autochlorinator. Now that they're gone and I'm using strictly LC the smell has disappeared.
  6. #16
    waterbear's Avatar
    St. Augustine, Fl
    Actually Carl, I've done quite a bit of research on this and have discussed it some with Richard. There is some evidence that the calcium (actually, the harder water) helps prevent cobalt spotting (black spotting), which is a problem with fiberglass pools. (Cobalt leaching from the gelcoat. Cobalt is a component of the resins used in fiberglass.). Cobalt spotting is probably only second to iron staining as a downside to fiberglass pools but both seem to happen much less with higher CH. (For example, my own pool is filled with soft water and I had frequent problems with iron stains, usually requiring an ascorbic acid treatment every 6 months. Once I raised my CH to around 350 ppm about 2 and a half years ago I have not had ANY staining problem and have not needed ascorbic acid.) However, unlike iron staining, cobalt spotting if often difficult or impossible to remove. There has been discussion about this on a different forum, btw.
