Results 1 to 9 of 9
Thread: no pressure on recirculate
    May 2010
    Default Losing water flow to the pool on recirculate and filter modes
    I have hardly any water flow going into the pool and this is on recirculate, i'm just starting up for the season. also sounds like bubbles coming thru the heater lines back to the pool outlets. any ideas thank you , timmy greene
    Default Re: no pressure on recirculate
    I'm not the pump expert around here but somebody will be along shortly who will be able to help you. I just wanted to say welcome to the Pool Forum! Glad to have you!
    May 2010
    Smile Re: no pressure on recirculate
    thank you so much.
    Honesdale PA
    Welcome to the forum too.
    What is your pressure? That tells a lot. High pressure indicates a pressure side blockage while low indicates either a suction side lockage, gunked up impeller, or air being sucked in. The gurgling in the heater could just be trapped air that isn't being purged due to insufficient flow. Can you see air in the pump basket? If it is air leaking in on the suction side look for the obvious first like the gasket on that pump basket lid. All it takes is a very tiny air leak to mess things up. We'll figure this out.
    Edit: I just read the post again and you said no pressure. Are you saying the gauge is reading very low or just no flow to the returns?
    May 2010
    Its low return flow, but I'm going to replace gasket in pump basket and o-ring on vari-flo head to sand filter base. And I'll let you know how it works. Thanks, Timmy
    Hey Timmy welcome here!!!
    Al's got you covered on where to start looking. As you find out more, keep us informed and we'll not only help you nail down the problem but, also, tell you what needs be done to fix it - so you can decide whether or not you want to tackle it yourself
    May 2010
    Unhappy Re: no pressure on recirculate
    OK I've changed gasket for pump basket and o-ring @ the vari-flo valve and base. also checked all conections from pump to the filter.started the pump up on filter, window showed no bubbles yeah. But awhile later hours rechecked, guess what saw my old friends bubbles. Rechecked all connection all threads no water leaks maybe a few drips around vari-flo head and sand base. Even checked drain plugs on pump basket. restarted everything looks good for awhile then bubbles come back and water level in basket dropped about 1/4 of inch and all kinds of bubbles. Note that when I started my pump in filter guage reading 24PSI any suggestions.
    Honesdale PA
    Sure sounds like an air leak somewhere and that somewhere would be on the suction side, not the pressure side so concentrate on the suction side. It also sounds like a very tiny leak and that's all it takes. You can try smearing vaseline around the pipe joints as it is thick and if you have a hairline crack that should seal it. Then fix it when you find it. Don't leave the vaseline on O-rings or gaskets for any period of time. Vaseline is cheap and cleans off easily. Also, is yours an above or in-ground pool? Reason I ask is for access to the skimmer basket connection. Under a deck can be a dog.
    May 2010
    its a inground pool . i noticed this morning that when i turned the pump off i had a little stream of water shoot out the side off sight cover at the pump. do i need to glue the gasket in the basket for it to seal proper. also heard small sound of air around the handle at the sand filter, don't know if thats where air was in the basket. just some things i wanted to shoot out there to you. again thanks for the info. if i was to have to glue the gasket what type of glue would you use.
  1. What does Recirculate do on my pool filter?
    By bonehead in forum Pool Equipment & Operations
    Last Post: 06-28-2013, 04:32 PM
  2. Recirculate?
    By jmjbj_h in forum Dealing with Algae & Slime
    Last Post: 05-04-2007, 11:30 PM
  3. Poly 60 in pool. Filter or Recirculate?
    By jdolby in forum Dealing with Algae & Slime
    Last Post: 06-01-2006, 03:39 PM
  4. Pressure guage under pressure!
    By rustypixel in forum Pool Equipment & Operations
    Last Post: 05-02-2006, 02:56 PM
