Re: no pressure on recirculate
its a inground pool . i noticed this morning that when i turned the pump off i had a little stream of water shoot out the side off sight cover at the pump. do i need to glue the gasket in the basket for it to seal proper. also heard small sound of air around the handle at the sand filter, don't know if thats where air was in the basket. just some things i wanted to shoot out there to you. again thanks for the info. if i was to have to glue the gasket what type of glue would you use.
