Results 1 to 10 of 16
Thread: Aqua Rite = Amperage
    May 2010
    Default Re: Aqua Rite = Amperage
    A Hayward rep claims my model uses lower amps and all I need to do is add a little phosphate lowering stuff. I am doubtful since the Hayward web page doesn't have anything about another model similar to mine.
    Does anyone out there know if he is telling me the truth?
    mas985's Avatar
    Pleasanton, CA
    I can give you a few data points that I have logged in the past. I have a T-15-Cell.
    87 degrees, 3000 ppm salt, 26 volts, 6.30 amps.
    100 degrees, 3000 ppm salt, 25 volts, 7.2 amps.
    So at 90 deg, 3500 ppm, the amps should be higher than 7.
    What cell are you using?
    Mark
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    I have a T-15-Cell currently at 24.2V and 6.4A. Salt is 3500 and 72 degrees.
    Like mas985, I'd like to know what cell you're using.
    I've used phosphate lowering stuff twice over the last 8 years when phosphates got to 3500+. Basically had an algae bloom with the only evidence being no chlorine residual and that condition kept coming back over a month even though I had shocked repeatedly.
    I didn't have time to keep shocking so it worked for me but that's a rare condition. I'll almost bet if you shocked your pool HARD you'll be back in business.
    Hope this helps, Tony
    May 2010
    Since my "new" system is not operating at the amps or volts normally to be expected I have to conclude that while it may be working to some extent it is not functioning to its optimum. My best guess is I was sold a used or defective system. I will be following up on this with my dealer and if necessary Hayward.
    I am particularly upset with being lied to by the Hayward rep who claimed there were 2 T-15 Cels. In response to an inquiry direct to Hayward they said there was only one T-15. I will definitely let Hayward know of this deception.
    By the way a phosphate test indicated my level was only 500, which is really not very significant, but anyway I have now added a phosphate remover and a clarifier.
    Also, I am still at 3500, 26+volts and 3.2+ amps, temp 86(today).
    I am going to ask the dealer for a complete replacement. I have hesitated to open the cel to see if it is calcified or otherwise compromised but will ask him to do so to satisfy my curiosity.
    Thanks to everyone for all your help.
    May 2010
    Quote Originally Posted by vicar8 View Post
    TWO T-CELL 15s? That seems odd. Perhaps he meant to say that they have different models with different capacities (I think the "15" just indicates the length of the connection cord, anyway).
    Not sure why some cell manufacturers are so fixated on phosphate levels -- 500 is pretty close to what I have (250 PPB) and I've experienced no issues with my almost 3 year old Goldline Aqua T-CELL-15. Much more problematic would be pool water to which lots of sodium bisulphate (dry acid) has been added, very high calcium and/or out-of-range pH.
    It's truly very easy to dismantle the cell for inspectiion -- turn off the power and loosen the two unions at each end of the cell. Hold it up to the light (sun or flashlight) and look for encrustrations. Only do a muriatic rinse/soak (4 parts water to 1 part muriatic acid) if there is obvious build-up on the plates or as a last resort. My Goldline manual suggests using a stick (!) but I've never tried this or needed to.
    EDIT Original reported Phosphates at 250 PPM (parts per million). Corrected to PPB (parts per billion). 5-17-10 END EDIT
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
    May 2010
    I can't seem to find the page on which I got the amp and volt specs. Can you help?
    Would a t-3 model have different specs than the t-15?
    May 2010
    Default Aqua Rite = Amperage
    Apparently he(the Rep) was. It has all been a terrible mis-communication. Each of the Aqua-rite models has different proper operating specs. My T-3 ranges are 1.30-3.91 amps and 23.8-28volts.
    The Hayward and Goldline manuals really need improvement explaining spec ranges for each product and what they mean as well. All the diagnostic numbers should be fully explained.
    Be aware that specs depend on which model you have. A T-15 has different specs vs. the T-3.
    I finally cut through their mis-information and poorly written manual. My system is a T-3 and is working quite well.
    Bottom line.... Hayward really needs to revise their manuals to avoid all the confusion they and untrained dealers lacking knowledge cause.
    They appear to have a good product.
