Closed Thread
Results 1 to 8 of 8
Thread: New pool, pump question
    mas985's Avatar
    Pleasanton, CA
    Default Re: New pool, pump question
    I agree with Dave, .75 HP full rated is more than enough. For a given pool design the THD drops with the pump HP so you will get plenty of flow and save on electrical costs.
    My guess is your head loss for the .75 HP pump will be close to 40 ft while it would have been up near 60 ft for the 1.5 HP pump.
    Mark
    South Florida
    I traced the pic of your pool and it looks like about 15,000 gal, and mabye a shade under. The beach entry has almost no water and I took that into account. 1hp uprated or 3/4 hp full rated is all this pool should need unless there is some other waterfeatures that we don't know about.
    Also, 2 skimmers is overkill for this pool. And if I may suggest, the beach entry should be a beach step instead.
    Zina
    Pool-Design . net
    GTakacs is offline Registered+ Thread Analyst GTakacs 0
    Quote Originally Posted by PoolDesignnet
    Based on my calculations the beach entry will hold around 260 gallons of water.
    There will be a 12ft x 2 ft x 2 ft cascading waterfall but it will have its own pump (the designer added in a 1hp pump for that, don't ask if it's full rated or up rated, I do not know). They were going to run the waterfall off of the same pump as the pool but I said no!
    This particular builder builds every pool with at least 2 skimmers, other than the cost, is there another drawback to having two skimmers? For the beach entry, my wife really wanted a true beach entry so that is what we're going with. They are installing a return (a 5th one) in the middle of the beach entry with a directional jet to move the water. I hope we won't regret it. I have read the possible problems with a beach entry I just hope that my builder is familiar with building one and will overcome them.
    I haven't mentioned that I'm getting Pebble Tec for the pool including the beach entry and I will have a Levolor Water Level system isntalled to keep the water level constant.
    South Florida
    Hi,
    I was concerned with the size of the beach entry. Looks like it will be about 10' into the pool. About 3' of that area will be dry. That leaves 7'. With the slope of 1' in 7' it will drop 12" in depth over the remaining length. There will be a drop-off at the end of that on the right side and two additional steps on the left. While it may look nice, it's not a very functional area. Just my 2 cents....
    Pebble tec is the only way to go on a beach entry pool. You may even do that in a sandy beach color and the rest of the pool in blue or what ever color you have chosen.
    Zina
    Pool-Design . net
    I am aware of the above issues, it is what the wife wants so this is what we're getting. We're paying a fortune for nothing essentially as far as swimming area goes. Your math is correct, we're doing a 1' in 7' drop down to 12" water level then two more steps at 10" each for a total depth of 42" at the shallow end (3.5 ft). I have an 18 month old son so I hope to get at least some use of the area for a little while.
    We'd love to get a separate color for the beach entry, unfortunately they're asking a $2000 surcharge for a second color, I think it's excessive. I will double check on these numbers, but for now I think we're going with a single color.
Closed Thread
