Good. Keep us posted. And .... then -- no more trichlor. Trichlor does have its place in pool care. If it is a fresh fill where you know there is no cya, you can use trichlor to add chlorine and cya at the same time, but you have to monitor the cya level as it builds up. Once you hit somewhere between 30-50 cya (I like around 40), you have to discontinue the trichlor.
Did you look at the ingredients of your 'shock'?
