Pool for the deployed troops
I'm not sure if this is the correct place to put this post, but I have to start somewhere. I am currently deployed overseas and our location has a empty concrete pool of which we are looking to get back in operation. Leadership here is excited to get this project moving, but I need to come up with a cost estimate to get it up to speed.
The pool is 60' x 40' x 5.5'. I est. ~ 100K gallons. All the equipment has been torn out and is gone, so we need the filtration system from the ground up. All the installation will be done ourselves (plenty of competent folks to do it). Here are the questions I have:
1) There are 4 x skimmers, and 4 x return lines. Looking through the flow rate calculator, I think I need a pump capable of > 166GPM using a 10 hr turnover. What size pump do I need for this?
2) With the above information, what size filter? Would a 36" sand filter be adequate?
3) The pool is rough concrete. There is no requirement for any of it to be pretty, just functional. There are several cracks along the bottom that allows seepage INTO the pool. I'm assuming to fix these we will need to chisel out the cracks and refill to seal them. What is the recommended material for this?
4) The rough concrete needs to be painted. Would a cheaper acrylic pool paint be sufficient considering the longevity of our possible occupation? Or would it be better to splurge on epoxy paint from the get go? We do have industrial epoxy paint they use on the auto shop floors. Are they created equal?
5) Chlorine vs salt vs whatever. I'm only familiar with chlorine pools. All the rave seems to be with salt pools now days. What is the initial cost and continuing maintenance cost difference? Contrary to popular belief, there is not an abundance of money to spend on 'moral' projects.
I'm sure there are other questions that I can't think to ask at the moment. Please send any and all recommendations to me.
I hope there is someone here that can help with my questions or at least direct me to someone who can. I appreciate your time. If we can pull this off, there will be a multitude of troops who will benefit from the effort!
In your service,
Robby
