Results 1 to 10 of 23
Thread: What to do??
    Lehigh Valley, PA
    Default Re: What to do??
    That sucks, about having to give up your house for a highway. Eminent domain, everybody's nightmare. Here in my area it's humongous power lines.
    I wouldn't worry about the bumpy surface as long as you don't have sharp rocks or roots poking through. Pollen and other debris tends to collect in the dips but you can brush/swish/vacuum that out.
    I'd patch the liner and make do for this season.
    Lightbulb Re: What to do??
    Don't know how viable this is but, as you'll be forced out of your home ~soon, maybe ditching the pool and getting an Intex quickset would be an option ?
    That's really horrible. At least the land is going for a highway and not to allow some developer to build a shopping mall on land he got below market value via eminent domain.
    You probably won't get your money from the state so I'd invest as little as possible in this pool. If you can't take it with you, don't spend $$$ on it.
    Will they at least cover your mortgage???
    se missouri
    We have no idea how much they are going to give us for the house. The price erosion in the housing market has me worried.
    We are planning to rebuild elsewhere on our farm but our hands are tied now.
    Fortunately there is no mortgage. worked real hard to get rid of that.
    As of right now I'm just going to try to fix the hole and replace the pump. I emailed the highway department today and they said it can be as soon as July 2010 or as late as June 2011. Quite a spread there. aint it.
    linerworld.com has a pump with free shipping for less than $200.00. what do you think?
    Thanks for the input.
    Lehigh Valley, PA
    Free shipping is always good.
    I don't know if this link will work for you: http://tinyurl.com/39gyrh7. It's a Google Squared search for 'above ground swimming pool pump'. Click on the down arrow in the PRICE column and sort from A-Z which will then show prices from lowest to highest. There are a number of pumps at HP from 3/4 to 1.5 at under $200.
    I'd put as little money as possible into the pool to make it functional for this year. How long is your swim season where you're at? Of course, the pump is something you can take with when you relocate the pool and it might make sense to get the best you can afford.
    Regarless of what state you live in, an Above Ground Pool is not considered a permanent structure and therefore not part of the real estate. Only permanent structures that are actually attached to the surface of the ground or IN the ground such as INground pools, sheds, garages, outbuildings and your home are part of the real estate - even mobile homes (unless they have a basement and brick or concrete foundation - not a slab) are not permanent structures. Unless there is something completely different about the Assessors in your county, they will not assess the property at a higher value for eminant domain if you have an above ground pool. It is treated no differently than having a trampoline or sandbox on the property. You should be able to remove it without having to buy it back from the state.
    se missouri
    Decided to fix it anyway. I was amazed, those underwater patches actually work.
    My son-in-law was helping and he said "this aint gonna work". about 30 seconds later he said "this is gonna work!!!"
    I ordered a new 1 hp Hayward pump from Amazon for $144.00, I had a 1 1/2 hp in my cart and remembered some sage wisdom from this site about too big a pump. So I came back here and did a search and found bigger was not better, and I switched it to a 1 hp. It originally had a 1 1/2 hp.
    Have pumps gotten cheaper? Last fall I couldn't find anything less than about $300.00.
    Thanks for the advice.
    se missouri
    Quote Originally Posted by NWMNMom View Post
    I wonder about the deck I built 1/3 of the way around it. Also it is on a concrete ring I poured prior to setting the pool up. I actually want them to have to buy it from me. Normally they sell it back to you at a greatly reduced price. I am pretty sure they at least have to pay me to move it. But then again it is the government
    Unfortunately, this is NOT necessarily true. It depends on the state, the local authorities and regulations and the nature of the pool.
    Since many localities, especially East Coast and suburban ones, require a building and electrical permit for ANY pool (If they are really pushy they may even demand one for an Intex-type donut pool), they may then consider it "assessable". That certainly happened to me, as my FantaSea pool is above ground, but built into my deck and, while technically "temporary", without a BobCat or 15 guys to lift 900lb girders, it's permanent!
    Our tax assessment DEFINITELY went up due to the pool, although not as much as our neighbors' due to their IGs.
    In an eminent domain situation, though, one may assume that the powers that be will be looking to pay the LEAST they can get away with, so they'll have an incentive NOT to include the pool in the property valuation. You'll need to find out if the pool is supposed be included in the expropriation.
