Thread: Replace filter air relieve valve screen?
    May 2010
    Default Replace filter air relieve valve screen?
    Temporarily suppressing my usual catatonic state, yesterday I began to disassemble my Hayward C4025 cartridge filter for its annual cleaning. I noticed debris caught in the fine mesh screen at the top of the air relief tube had punctured the enclosure. Part of the screen is missing and the remainder just fell into my hand. I've ordered a replacement tube & screen but it will take a few days to arrive (won't pay $40 overnight for a $7 part!) and I would like to reassemble the filter and starting pumping.
    Can I run the pump/filter without the screen in place? If this is inadvisable, is there a jury-rig solution that will work well enough until the Little Screen That Could comes in? Thank you.
    Part reference: #11 D CX4000Z3
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
    mas985's Avatar
    Pleasanton, CA
    Default Re: Replace filter air relieve valve screen?
    I have run mine without the screen but it can get clogged much easier. Just make sure you manuallly bleed off the air after priming.
    Mark
    May 2010
    Quote Originally Posted by mas985 View Post
    Will do. Thanks, Mark.
  1. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  2. When to Replace vs. Clean DE Filter?
    By Hszwill in forum Pool Equipment & Operations
    Last Post: 07-28-2010, 11:08 PM
  3. How often do you replace your filter?
    By bkny1055 in forum Pool Equipment & Operations
    Last Post: 08-12-2006, 03:24 PM
  4. Polaris 360 Return Line Filter Screen Problem
    By ChiInSFO in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-05-2006, 05:55 PM
  5. new IGP, can they Marcite before Screen?
    By mneal in forum In-Ground Pool Construction and Repair
    Last Post: 05-23-2006, 10:02 PM
