Results 1 to 10 of 17
Thread: Help to clean your water
    IMherDad is offline ** No working email address ** IMherDad 0
    Memphis, TN.
    Smile Help to clean your water
    Last year I saw on this site someone who suggested using a Scum Sock to help control the "fine" particles in your water that your filter might miss.
    We used them at the end of the summer and it helped quiet a bit. So when I uncovered the pool this year and cranked up the pump you could see all the pollen and junk flying around in the air and even some in the water. It's just that time of year when you can wash your car and the next morning it's covered in a green film.
    So we started using the Scum socks and WOW... I was amazed at all the junk these things were picking up. Right now until all this spring junk quits flying around we are changing out our Scum socks at least three times a day and they are just nasty. There's just that much garbage in the air! And there are no trees within 60 yards of our pool.
    And our water in the pool? It's crystal clear. If you haven't tried some of these I highly suggest you do. In fact it's one of the best investments we've made for our pool. I think they come in a pack of three or four and cost less than $10.
    Default Re: Help to clean your water
    I was wondering if they were worth it...will give them a try now!
    nc.
    I agree,they well worth the money.
    Having an Intex Donut,with not the best pump and filter,those socks keep all the lil tiny stuff out.
    Margit
    PopcornGirl is offline ** No working email address ** Thread Analyst PopcornGirl 0
    Baton Rouge, LA
    Just a tip: I was told that old pantyhose would work just as well and are a great use for those with runs or holes that we would normally just throw away...
    Also, you might be able to purchase really CHEAP hose or knee-highs cheaper than the scum socks.
    I'm about to go through my sock drawer because I KNOW I have some old hose in there that would work!
    I'll let you know how they do...
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I was wondering if panty hose would accomplish the same thing... The ones in the catalog I get look like white knee high panty hose to me.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Memphis, TN.
    Well they are close but the scum socks have a lip stiched in them so they wont' roll over your skimmer basket.
    We tried using your idea first but they just kept coming off one side or the other so we spent the $10 and got the real deal.
    p.p.h. is offline ** No working email address ** p.p.h. 0
    Dec 2005
    Phoenix, AZ, usa.
    How do you clean them ? Or do you have to continue to purchase them?
    Baton Rouge, LA
    IMHerDad:
    Oh, I forgot that part... I was told to secure the panty hose with a large rubber band to keep it from coming off the skimmer basket.
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Just take the basket out, dump the large trash out, and wash out with a hose with a pressure nozzle on it. Put the nozzle on a "lighter" setting - a jet spray can put a hole in the sock.
    I only have to replace them because of tearing holes in them, which happens - otherwise, you can wash all the scum out. They will clog up a lot faster than a filter will (I have a cartridge filter) and need more attention if your pool is dirty.
    But I love using them.
    Memphis, TN.
    We purchased some the other day from Wal-Mart and I so far I really like those better than the ones from the pool store. They are a little bit larger and fit the skimmer basket better and seem a little heavier duty. The cost is about the same as the ones from the pool store.
