Results 1 to 10 of 11
Thread: Winterizing solar panels
    mas985's Avatar
    Pleasanton, CA
    Default Re: Winterizing solar panels
    Yes, that sounds like a true VRV. So you shouldn't need to do anything but turn off the pump to drain the panels.
    However, Sungrabber suggests that the panels be removed and stored before the first frost so they may not be able to survive the winter even if the water is drained from them. But you should problaby check with the manufacture.
    This is from their web site:
    Q. What do I need to do to winterize my system?
    A. The panel must be drained and stored before the first frost. If water is allowed to freeze in the panel, it may cause freeze damage. To winterize your system:
    1. Turn off your pool pump.
    2. Place the plugs given to you with your pool in the inlet and outlet of the pool.
    3. Disconnect both of the hoses from the hose barbs on the solar heater. Disconnect the hose from the pool inlet. Connect the hose from the pump to the inlet on the pool.
    4. Remove the plugs from the inlet and outlet of the pool and check the hose clamps you just tightened for leaks.
    5. Unscrew the white drain plug that's located on the panel end opposite the inlet and outlet.
    6. Roll the panel and secure using the yellow/black -carrying strap. Tilt panel until water no longer comes out. Replace drain plug, and store the panel and plumbing in the garage or a shed until next spring.
    It sounds as though the water in the panels is the issue and would not be a problem if drained properly but they still suggest that they are removed. Other panels can be left up during the winter but is seems as though these cannot.
    Mark
    Ohio, North Canton
    I read that same thing in my installation manual, but was confused as to how I was supposed to remove the panels from the roof. Afterall, I have 3" lag bolts going thru my roof holding the straps down that hold the panels in place.
    Am I supposed to remove the straps each year to get the panels down??
    The other thing, I called the companies helpline when I was installing the panels. They told me that as long as I had the IG panels and had a slope on the panels of at least 1" for every 10' of panel, all I need to winterize them is pull off the inlet plumbing line to the panel, let it drain, and I am good to go. I don't need to take the panels inside. The lady told me if I had AG panels I would need to store them inside.
    I don't understand this.
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
    mas985's Avatar
    Pleasanton, CA
    That is good news. I suspect that the reason they told you to remove the plug is that they didn't know you have a VRV installed. With that and assuming there is no trapped water, you should not need to manually drain the panels. But you should check at least once before the winter sets in to make sure the panels are draining properly and completely.
    Mark
  1. Solar Panels
    By dhage in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2012, 11:57 PM
  2. Solar Panels and Solar Covers
    By FlowerPool in forum Intex-type Pool Setup & Operations
    Last Post: 05-22-2012, 07:12 PM
  3. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  4. Solar Panels - Spring Leaking/Winterizing Problem
    By huskerfan in forum Pool Equipment & Operations
    Last Post: 06-26-2009, 11:54 PM
  5. Solar Panels Q?
    By shanode in forum Pool Equipment & Operations
    Last Post: 05-16-2007, 06:04 PM
