Just purchased Clorox 182oz @ Sam's Wholesale for $7.18 for a case of 3. $2.39 a bottle. Clorox brand does not have those pesky "safety" tabs.
I have a plaster pool so calcuim levels are not a problem. Today I found 100 lb. of calcium hypochloride at the pool store (granuale chlorine labeled shock) for $177 before tax. 3/4 of a lb. of cal hypo = 1 gallon of bleach. Just to check the math 1 lb. gives 80,000 gallons 1 ppm. That 8 ppm per 10000 gallons. Bleach gives 6 ppm per 10,000. 6/8 = 3/4.
So 100 lbs. is equal to 133 gallons of bleach. Walmart sells 1.42 gallon bottles for $2.52. That is approxmiately 94 bottles. So the cost we I live would be $236 before tax. So buying 100 lbs. is a bargain for chlorine and much less than bleach. Note this may not work for smaller sizes 50 lbs is $112. Equal amount of bleach would be $118 so it gets pretty close here.
However, those who do not have plaster and concrete might have a problem with the calcium levels rising. My pool actually needs a little more after draining over half to get CYA to 70. It is still a little high but much better. The local water has a bit lower calcium.
I think the reason I am switching is mainly because buying so much bleach takes time and bleach backspalsh has ruined more than one pair of shorts and a shirt or two. The cal hypo I bought states it is netural PH so it may bring the PH over time, PH 6.5 to 7 current PH is 7.5 with a slightly high alkanity of 140. So slowly taking down some PH isn't bad.
Bleach still has its benefits but it looks like the calcium is a better buy right now.
Well just my newbie 2 cents.
I found out that in Florida they sell liquid chlorine (BLEACH) for $4.49 for 2.5 gallons. It's 10.8 percent.
Now today I find out that once every 6 - 8 weeks they have a buy 2 get 1 free. So now you are getting 7.5 gallons for under $10 - now thats not all the time but if you factor it in long term it appears to really bring down numbers.
Plus they give you the 11th fill free - and (on top of it) wednesday they give you 2 "credits" for liquid chlorine.
I asked how "fresh" it is. They told me they get 15 thousand gallons every Thursday and use every bit of it up. THey said after 30 days it loses about 10 -15 % potentcy and gets worse as time goes on..
So today I bought 2 gallons - got 1 free but I got 6 "credits" so 4 more buys and I get one more free.
Again, I dont know where you live or what is available. But doing rough math in my head with the price, bonuses, and buy 10 get 1 free: Planning my purchases on Wednesday and all that - it really works out to be a bargain.
And you are getting straight up liquid chlorine and you don't have to worry about CYA.
I am a TOTAL newbie. My pool has been running for about 24 hours now -- so I am just sharing what i've learned thus far...
Great price! I pay nearly $20 for 5 gallons of 12%.
You can test the strength yourself. You just need to dilute the LC 10,000 times and measure it with a FAS-DPD measure just like your pool.
10,000 TIMES??????
Yeah. You add one CC (Milliliter) of LC to 10 liters of tap water--that's 5 soda-bottles full. You can usually get a marked eyedropper that has an ML marking on it--and 10 liters easily fits in a five gallon bucket.
You know, I oughta do a sticky post on testing liquid chlorine strength.
Oh, yeah--test the chlorine content of your tap water BEFORE you add the LC---you may well get a reading of 1-3ppm of FC.
I actually did test my tap water - more so to get "used" to taking measures - after 2 or 3 days I feel like an old hand
My tap was about 1.5 FC
Another way to dilute chlorine for testing is using a syringe (without the needle). You need one which measures 10 ml (10 cc).
Put 10 ml chlorine into 1 liter of water, mix well. Put 10 ml of the mix into 1 liter of water, mix and then test that.
