Hi Sean.
Thanks very much for the info.
How about electrical requirements ?
Will a 20AMP line be good ?
Tim
Hi Sean.
Tim
The Digital unit alone, uses 220 volts @ 1.5 amps. For the Total Control, the acid pump draws around 0.5 amps.
Remember though, that the Pool Pilot should be tied into the same relay, switch, or breaker that the pump is wired to. So, consider what your pump amperage is, then add about 2.5 amps for the Pool Pilot portion.
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
Are they available in 120 volt too ?
My Pump is currently a 120 volt/ 20 amp.
Yes. Part number are the same, except for the acid pump/tank. Use #75004.
Amperage draw will be 4 amps, basically double the 220 volt amp draw.
You can also run the pump through the DIG too. There's a built in relay and time clock function to allow you to control the pump through the DIG panel.
If you choose this option, you'll also need to get #75008, acid pump/aux relay kit.
Sean Assam
Sean,
Thanks again for the quick response.
I appreciate your help.
Regards, Tim
