The Digital unit alone, uses 220 volts @ 1.5 amps. For the Total Control, the acid pump draws around 0.5 amps.
Remember though, that the Pool Pilot should be tied into the same relay, switch, or breaker that the pump is wired to. So, consider what your pump amperage is, then add about 2.5 amps for the Pool Pilot portion.
