Re: digging around the pool
Maybe to late on the reply.
Pumping the water from around the sounds good but if you are in the middle of the repair and a bad rain storm comes in and nocks out the power then you are in a heap of trouble. As you drain down the pool just drill 1/2" holes lower down in the walls and then a few in the shallow end and a few at the transition and a few in the deep end (only if you know the location of your plumbing lines). Using the pump around the pool wouldn't hurt either.
Make sure the french drains drain some where and not just sit under the pool deck.
For back-filling the pool use 3/4" washed stone around the pool and under the pool deck compacted in 8" lifts.
Do not tie the pool to the deck because if the deck moves it will crack the bond beam; then you will have a cracked pool and a sunken deck.
Hope this helps
