Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: New to BBB
  1. #21
    Default Re: New to BBB
    Quote Originally Posted by rkelly View Post
    . I usually did every Sunday night using shock. need to
    Remember, shock is something you do TO your pool, not an ingredient you put in it. If the "shock" you're talking about is pre-packaged dichlor, then I would stop using it, because everytime you use it, it raises your CYA....it won't be long before you're going to have to up your base chlorine level to compensate for the higher CYA levels. That's one of the problems with the pool-store version of shock--they sell you packaged "shock", which raises CYA, which raises base chlorine requirements, but they don't tell you that--so when your pool gets cloudy and green because the chlorine is too low, they sell you more "shock", and raise the CYA further. After several cycles of this, people usually find their way to this forum and realize that the "shock" they keep adding is the problem. (It also contributes to low pH problems). If you'll use bleach or liquid chlorine both for shocking and for regular chlorination, it will not drive up your CYA,will not drive down your pH, and will save you lots of time and aggravation in the long run!
    In effect, when one has an appropriate Free Chlorine (FC) level relative to the Cyanuric Acid (CYA) level based on Ben's Best Guess CYA chart, then you are continually oxidizing bather waste and other organics and preventing algae growth with no need to shock the pool (i.e. no need to periodically raise the FC level).
    The main reason shocking is needed in non-BBB pool care is that the CYA level climbs and the FC level is too low so that you need to periodically raise the FC level weekly to try and catch up. Eventually, you fall behind anyway and get mysterious chlorine demand or dull/cloudy water or visible green algae. All of this is avoided with BBB by simply maintaining a consistent and appropriate FC/CYA ratio. So simple, yet so effective.
    Richard
  3. #23
    May 2010
    412 Tramway West Road
    Thanks so much for all your help and advice.....
