Re: two openings(holes) where skimmer is
timmie
Thanks for the reply....BUT.........do I have to put the flap over the other hole, or should both be uncovered? I do not know much about pools.
AnnaK's post reminds me to confirm what I should have asked you initially: You're starting up an in-ground pool? Depending on how your pool is plumbed you might not need the flap-- but so we're on the same page, could you identify the skimmer brand and part? See links below to view a skimmer parts diagram for a popular model (Hayward Skim-Master SP1070). If you don’t have or use a float valve assembly in the skimmer my guess is that the part in question is a skimmer throttle slide plate. It attaches near the port with a screw and can be pivoted to cover it.
Which hole? Almost always the port that is furthest from the pool is the suction pipe that leads back to the main pump on the equipment pad. If you use the throttle plate, that’s where it would go. If you don’t recall its placement from last year it may have been screwed in but not used. Throttling may be useful if you have multiple skimmers and vacuum using a suction hose/head. Partially covering the port will increase suction-side head (reducing flow) and allow more suction to develop at the vacuum head for better cleaning. But for normal operation, don't cover the hole.
The other port, nearer the pool, could be plumbed to a main drain (MD) or it could be unused and will likely be only a few inches deep leading to concrete. Use a tape measure or a long thin stick to probe each port (hole) in the skimmer to find out. If it dead-ends you could insert a plug or just ignore it.
http://www.inyopools.com/pool_parts_hayward_sp1070_sp1071_skim_master.aspx
http://www.inyopools.com/pool_part_cat_Skimmer_Parts.aspx
16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
