Results 1 to 10 of 14
Thread: Need Help!!!!
    May 2010
    1615 sandhill game mgmt road
    Default Re: Need Help!!!!
    ok yesterday i added 12 gallons of bleach and this morning i added 3 more gallons went and got a water test this afternoon and this was my readings
    ph 7.5
    tc 10
    fc 10
    alk 91
    the woman at the pool store didnt give me a cya she just said it was low guess since i wasnt buying nothing she wanted to be snotty so how much more bleach am i going to need to add the water it is still cloudy and cant see the bottom but i know thats not gonna happen over night what do i need to add for stablizer and for how loing do i need to keep adding the bleach to kill the algea bloom
    You need to keep adding the bleach until the water turns blue and the cloudiness starts to clear up. With sustained chlorine levels, it probably will take 2-4 days, depending on how consistent you are. Once it's turned blue, the cloudiness is mainly going to be dead algae that your filter will have to get out--so make sure your filter is running 24/7, and backwash it as needed when your pressure rises. Brushing your pool daily will help, but the key is to sustain that high chlorine level--don't let it yo-yo up and down. Hang in there, it's going to clear if you keep the chlorine up!!
    The stabilizer is CYA--sold as "balancer" or "conditioner"...the ingredient is cyanuric or isocyanuric acid. I wouldn't worry about adding it right now--get your pool clear first and then add the stabilizer. You're going to be backwashing your filter frequently while clearing up the bloom, and the stabilizer will just wash out.
    If there's not another pool store you can buy the smallest amount of stabilizer (CYA) they sell, just to get them to give you a reading on CYA. If your first #s were right, you don't have any CYA and you'll need to add it sooner or later--and that's something you have to buy at pool stores anyway.
    Also, WalMart sells CYA in a 4 lb container. Last few years I found it in a 2 lb container in the section for spas and hot tubs, but this year they didn't seem to have it...don't know if they were out or if they're not carrying it anymore.
    Follow label directions for amount to target 20 ppm in the pool, but don't broadcast it over the pool like it says to...instead, put it in a knee hi or old tube sock and hang it in front of a return. That way it won't wash out when you backwash your filter.
    May 2010
    OK I am keeping my chlorine up high and since thurs I have added 24 gallons of bleach should I be seeing a change by now or am i just impatient the water still looks to be the same I have been brushing every day how much more bleach do i need to add and when do u think i will start seeing a change down to 4 weeks before my party found me some stab at lowes so i will add it once i get it cleared up . Have been adding bleach at least twice a day .
    With no stabilizer in the water, make sure that at least one of your bleach additions is happening in the evenings so that the bleach has the whole night to work on the "stuff" in your water without the sun degrading it.
    Is the pressure on your filter rising? How often are you backwashing? How does your water look? Is it still blue/cloudy, or is it green still?
    You should start seeing results soon, if you're able to consistently keep the chlorine level above 10.
