Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: Salt System newbie
  1. #31
    May 2010
    Default Re: Salt System newbie
    Quote Originally Posted by jeffvrba View Post
    I’d like to see that spread sheet but I couldn’t PM you, can you send it to me?
    Do you know how many gallons of water are in your pool? I can send you the info based on that, or do you want the entire sheet?
  2. #32
    Houston.
    BTDG,
    Here are a couple good tools for pool calculations. Both were created by people on this site and a predecessor to this site.
    http://www.poolcalculator.com/
    http://www.troublefreepool.com/bleachcalc-t110.html
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
  3. #33
    May 2010
    Quote Originally Posted by BigTallDumbGuy View Post
    You can send the entire sheet, I love Excel.
  4. #34
    May 2010
    I think you can send me a PM now that I am a subscriber. I can send the file to whatever e-mail address you give me.
  5. #35
    May 2010
    As I wrote, the reason for the higher CYA for an SWG pool is to reduce the rate of pH rise by reducing the rate of chlorine consumption thereby letting you lower your SWG on-time.
    If you are not experiencing a pH rise that you find intolerable, adding a lot of acid every week, then you can certainly leave your CYA at 50 ppm and keep your FC at least at 2.5 ppm if not 3 ppm minimum. That's perfectly fine and is totally up to you. I was only explaining why a higher CYA is usually done in most SWG pools -- it is a legitimate reason that works well in most cases.
    I have come an unbelievably long way since I joined this forum and I just wanted to post an all around Thank you to everyone, especially CarlD, Chem Geek, Watermom, and Ben (for providing and maintaining this forum). THANK YOU FOR ALL YOUR HELP AND TOLERATING THE NEWBIE.
    My most recent stats are as follows:
    CYA 50-55
    FC - 3.0 (morning reading)
    TC - 3.0
    pH - 7.4 - 7.6
    I now run the system for 5 hours a day, which is pretty close to what I ran it for using traditional Chlorine, and my SWCG is set at 80% output. This gives me a FC reading of 2.0 at sunset. I have only added less than 1 gallon of muriatic acid since I bought the box over 3 weeks ago (I hope this stuff don't go bad in the box). It only seems to require a cup or two every third day. So I would almost say this is a tolerable level.
    The Crux of the issue is this. I went from "Turn it on for 12 hours a day and forget it" to a properly maintained, sparkling clean pool WITH NO BURNING EYES, and an electric bill that is as it was.
    The only problem I have now is convincing my wife that I am not an excessive/compulsive pool fanatic.
  6. #36
    Jun 2010
    Northcentral MS
    Thumbs up Re: Salt System newbie
    Hi BTDG (And others!),
    This is my first post as a member and I just wanted to say I have been reading a lot over the past few days and I pretty much fall into BTDG shoes (as far as pools go .
    I am a pool newbie with a SWG system (AutoPilot), all fresh and new and I decided at the last second to go this route because of this forum.
    I plan to follow the advice given by the members to BTDG to get my pool going. I'm sure I'll have questions, but these four pages of post really hit home with my setup.
    Just wanted to say Hi and Thanks!
    Michael
  7. #37
  8. #38
    May 2010
    Quote Originally Posted by zmachines View Post
    Michael
    Hi Mike. Welcome. You came to the right place. This is the most incredible Forum. There is tons of support, knowledge, good information, tips, and world re-nowned experts to answer your questions all under one roof. Good Luck.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  3. Intex Salt Water system newbie
    By codes4food in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-11-2011, 11:06 PM
  4. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 05:37 PM
