Re: Who loves their Polaris 380?
While I have always loved my 380 I am about to replace it. If anyone wants one let me know. The problem was not with the unit itself, it was that I developed a leak in the feed line somewhere between the pump and the outside wall of the pool. Since it is under a concrete deck my pool builder told me it would cost $500 to cut the concrete fix the leak (he assumes it is right at the wall) and then patch the concrete. If it turns out to be somewhere else well there will be more money spent. Since I have used it for 7 or 8 seasons I am not sure how much life the pump will have left nor the unit itself. Further, it is expensive to run as I have to run my main pool pump and the booster pump for it to work. So, rather than spend good money after bad I decided to spend $1,000 and buy a Dolphin Dynamic -- just ordered it today.
