Thread: Advantages of 28 mil vs. 20 mil liner?
    Default Advantages of 28 mil vs. 20 mil liner?
    Have to put in a new one. I've always used 20 mil and my usual pool guy says there is no real advantage to the pricier 28 mil, but thought I'd ask the group her before deciding. thanks
    Default Re: Advantages of 28 mil vs. 20 mil liner?
    I just replaced my 8 year old 20 ml with another 20 ml. If you look at the amount of physical difference between the two, you're basically talking about the thickness of a sheet of paper. IMHO, if something's gonna puncture the 20 ml, then that sheet of paper isn't gonna help you much...I'd save the extra money and spend it on bleach.
    Just my opinion, and what I did!
  1. Any advantages?
    By Charlie_R in forum Pool Equipment & Operations
    Last Post: 08-11-2012, 02:44 PM
  2. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  3. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  4. Polymer Pool Bottom: Contour or Square- advantages?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 03:07 PM
  5. Do I need "Liner Lock" for Beader Liner
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2006, 12:04 AM
