Thread: First go with the 234 kit
    IMherDad is offline ** No working email address ** IMherDad 0
    Memphis, TN.
    Default First go with the 234 kit
    Number are as follows. Any help since this is my first test with this kit????
    FC - .5
    CC - .5
    TC - 1
    PH - 7.5
    Alk - 80
    Cya - 30
    Thanks in advance.
    barry
    Memphis, TN.
    Default Re: First go with the 234 kit
    According to the bleach calculator that would be about 5 1/2 gallons for a pool that is our size (33' oval 42" deep)
    Memphis, TN.
    2nd go three days later with questions.
    FC - 3.5
    CC - .5
    TC - 4.0
    pH - 7.2
    Alk - 60
    Cya - 30
    Should we add just a wee bit of Cya and bump the pH?
    duraleigh Guest
    Hi, Dad,
    You're havin' fun with your kit, aren't you? Isn't it great to have your water under such good control?
    Personally, I would leave CYA alone and keep an eye on pH and Alk. If the pH slips any more, it's time for a little Borax. Most folks like Alk around 80-120 but you're not in any danger zone...a little baking soda would put you right in the ballpark.
